Ricoh IM2702 Drum & Blade
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I will be replacing the drum and blade on a IM2702 next week...
    Service manual states to run SP2-801-001 - Dev Initialisation/TD sens exec to reinitialise the TD sensor and SP7-622-021 to reset PM counter.
    Is this accurate because I would have thought you only run the dev/TD initialisation when you have replaced the dev?
    I thought I would only need to reset the PM counter for the OPC drum?
    TIA
  • GIUBOSS
    • 1435
    if you replace only the drum and blade you will have to reset only these parts (if they appear individually in the PM parts list)
