Ricoh c5200s .. Turning off Fiery settings in SP so I can print direct from computer
  • stuinthecity
    • May 2023
    • 4
    I have used a couple Ricoh Pro c5100s and knew how to switch Fiery off in SP but just got a 5200 and can't seem to figure it out .. Are there more than 5193 and 5985? Am I wrong on even those!?
    Thanks for any help in advance!
  • anothertech
    • 1769
    Those are the correct SP's. Change them and reboot. If it still doesn't work, try removing the gigabit connector.
      • 37490
      I wonder, could the Pro C5200 be one of the models that optionally came with a factory installed Fiery and no GW controller? If that's the case then a GW controller will need to be installed.
      • stuinthecity
        • May 2023
        • 4
        Thanks! I managed to get the "Print" back on the screen. Now just trying to connect my computer to print from. Doesn't have the USB-B like my previous c5100s, just the USB-A slots. Slimbob you might be right that I need to install a GW controller .. It was so close to being easy
        • anothertech
          • 1769
          Is there a network port to connect a network patch cable? I believe the 5200 does has a GW controller built in.
          • anothertech
            • 1769
            On this PDF, it shows USB is number 6 and network is number 7.
