6002 fuser in a 6503
  • mikadonovan
    • May 2008
    • 2922
    Hi, All. Are the mp6002 and mp6503 fusers interchangable? I've never tried it, and I would hate to rebuild one in shop and find out it doesn't work onsite.
    NEVER ASSUME ANYTHING
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: 6002 fuser in a 6503
    I know the thermistors are different but the rollers etc are the same
    Regards Mark
    • apump
      • Mar 2009
      • 160
      no. 6503 uses 3 lamps
      • luca72
        • Oct 2017
        • 1842
        hello, some consumable parts of the kit are the same, but the complete unit is not interchangeable...especialy the web motor its 0.5 watt more power, and with different connector, but this can do installed anyway with a bit of hand
        Ricoh Aficio MP 6002 Fuser Rebuild Maintenance Kit - 450K (Genuine) - Genuine Ricoh Kit
        Kit Includes:
        (1) Hot Roller:MM40 [AE01-1117]
        (1) Pressure RollerIA40 [AE02-0209]
        (2) Ball Bearing 8X19X6 [AE03-0053]
        (2) Ball Bearing 40X52X7 [AE03-0054]
        (2) Oil Supply Roller Bushing [AE03-1026]
        (1) Fusing Cleaning Roller [AE04-2066]
        (5) Stripper Pawls [AE04-4060]
        (1) Pressure Roller Cleaning Felt [AE04-4068]
        (1) Cleaning Felt Roller: 32M [AE04-5067]
        (1) Middle Fusing Thermistor [AW10-0131]
        (1) Inner Back Fusing Thermistor [AW10-0132]
        Ricoh MP 6503SP 450K Preventative Maintenance Kit (Genuine) - Genuine Ricoh Kit
        Kit Includes:
        (1) Hot Roller / MM40 [AE011117]
        (1) Pressure Roller /DIA40 [AE020242]
        (2) Ball Bearing / 8x19x6 [AE030053]
        (2) Ball Bearing / 40x52x7 [AE030054]
        (1) Fuser Cleaning Roller [AE042066]
        (5) Stripper Pawl [AE044060]
        (1) Pressure Roller: Cleaning Felt [AE044068]
        (1) Roller: Cleaning Felt / 32M [AE045069]
        (1) Thermistor: Fuser Middle [AW100191]
        (1) Thermistor: Fuser: Inner Back [AW100192]
        (2) Plain Shaft Bearing: Oil / S[D0624226]
        *source precisionroller
        "I'll be back"
