Light Copies and prints on a AF3035
  • TCA TECH
    • Mar 2009
    • 104
    Hi all first post,
    I have searched through the forum and find some great ideas and work arounds so I thought maybe someone could help on this ongoing issue I have.
    Ricoh AF3035 with about 300K
    Just replaced;
    Dev and dev unit (replaced 3 devs and 2 units since new)
    Whole PCU (replaced about 6 times since new)
    Toner hopper assembly
    ID sensor
    Changed firmware
    Fully setup and stable for about 6 - 8weeks, customer changes toner and it just gets lighter, you go out and tone it up and then works fine. This has been a ongoing issue since new. Any idea's
    Copiers are only as good as there last service
  • rthonpm
    • Aug 2007
    • 2847
    If you've put that many parts into the machine at 300,000 clicks (drum should have been done twice and developer once by that point) I would look at the wall voltage and also whether the customer is using the right toner. Just my initial thoughts...
    • Ltd
      • 90
      Try this
      Replace new LD unit, it might help.
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        Often over looked are the cheap foam drum and dev seals.
        The toner coming out from the hopper can leak pretty badly at the drum seal if it's worn and the side is push inwards.
        I inspect and replace them at most PMs now and the machines as result are running much cleaner between PMs.
        • TonerMunkeh
          Professional Moron
          • 3865
          I think that's more likely to be the mylars in the toner hopper.
          Cipher's bang on with what he says too, however I do find it odd that it's only doing it when the customer replaces the toner. Is it OEM? Is the customer doing a couple of open / close front door cycles to force the toner in?
          Hit it.
          • TCA TECH
            • Mar 2009
            • 104
            Thanks for the response, the Idea that it all goes wrong after toner install really comes from the customer.
            Mylars are good as I did replace the toner holder assemble, seals are good as I replaced both the PCU and Dev unit.
            I have done a lot of reading on the forum and it seams that most have the same opinion about these machines as I do. But have definiately learned to look more closely to the polishing of Dev roller. Could this be the problem (polish the dev roller) Toner is genuine as not to keen on after market toner in dual component machines.
            Will read up on the LD unit as an option
            • Guvnah
              Toner Monkey
              • Mar 2009
              • 19
              helps a bit, but doesn't fix
              I have found that the customers tend to wait until the machine stops functioning before they add toner. If you can get the customer to replace the toner AS SOON AS the machine starts asking for it, the dev doesn't crap out as badly or as quickly.
              Keep in mind, it WILL crap out earlier than it should, but it seems that if the machines are let to run until the mix is thin everything goes to hell.
              • Noj7373
                • 20
                I've had a lot of the same experiences with this model. I've done all of the TB on this, Changed Bias, cleaned toner path, checked drum ground, Ect. I have one of the new Dev units that were released last week(B213-3011) on order, but wont be in until friday or monday. I installed three weeks ago the new dev unit for the MP4000 with the added 2 dev filters and coated mag roller. Checked on it this week and CQ is going light already. 70% of my units are the last generation 35/45 or the new 40/50 PPM, and I am getting very agrivated, because we use the BEI system and it is killing my only way of making real money. My worst machines I have convered to us the old toner and dev.
                • Llama God
                  • Mar 2009
                  • 1353
                  I've had quite a few problems with the MP5000s crapping up the mag rollers and, thus far, the mod dev unit seems to have fixed the fault.
                  I'm an eternal optimist though...
                  • Frank12
                    • Nov 2008
                    • 77
                    Originally posted by TCA TECH
                    Hi all first post,
                    Just replaced;
                    ID sensor
                    Changed firmware
                    take out the 2nd blade it will become fine
                    • paulg
                      • Jun 2007
                      • 278
                      Had one issue where the Toner bottle motor was on its way out so would turn but not always. Remeber a case of a 3035 having this problem and quite a few good techs go the machine up and running with forced toner, was working already by the time they got there or changing the toner hopper unit over. Even a dev change. The copier due to the light use it got went on with this problem for months.
                      • aabarnes1
                        • Mar 2009
                        • 620
                        I had an issue with a similar fault and the cause of that was the dev filter was missing therefore dev was spewing up onto the slit glass causing feint copies. I agree with what the lads have said to you about mylars and seals. make sure the mag roller is clean, should be silver in colour not grey or black, I use a green kitchen scourer with alcohol. There cetainly seem sto have been a lot of parts gone into this machine, has it had this problem before? It's not on and outside or damp environment is it?
                        Grant me the serenity to accept the things I cannot change.
                        • Llama God
                          • Mar 2009
                          • 1353
                          I had this problem too, after I sucked the dev filter into my vac and temporarily replaced it with some folded-up blue cloth. I say temporarily, what I mean is that I completely forgot about it until there was dev everywhere but, on the plus side, it wasn't me that went back!
                          What can I say, I'm a total cowboy, armed with electrical tape, superglue and a fistful of paperclips.
                          • TCA TECH
                            • Mar 2009
                            • 104
                            Sorry but which blade, (in the drum unit ?)
                            • Koosie
                              • Nov 2008
                              • 121
                              I suck those up all the time! I use a white cloth and it seems to work fine. (difficult to tell since these machines will be black on the inside either way)
