mp4001 doesn't show buttons in scanner menu
  • pakobernal
    • May 2012
    • 46
    Hi friend, I have a problem with a mp4001, I create the users in the address book, but the buttons don't appear in the scanner menu. Any idea?
    Thanks, and excuse me for my english.
    • 37575
    Re: mp4001 doesn't show buttons in scanner menu
    Sounds like none of the user have any destinations associated with them.
    • pakobernal
      • May 2012
      • 46
      I've created the users in web image monitor as always, I enter the data to authenticate, the path, .... but then no buttons appears on the machine. It's very strange.
        • 37575
        Try checking from the control panel. From there you can do a connection check for each path. And that is not the only thing that you can check from the control panel and not from WIM.
        • pakobernal
          • May 2012
          • 46
          Thank you very much, the machine is in a distant client. I'm going to try to connect remotely and check the address book and the machine, and try to create another user.
          • luca72
            • Oct 2017
            • 1791
            could it be that you have "display priority setting" set to mail, or vice versa?
            or you can make a backup of the address book (for safety) via wim, and reset the scanner application via sp and format the hdd
            "I'll be back"
            • Drivee
              • Nov 2020
              • 322
              Hm.. printer have numbers, every user is 1 number. So, when you scan something, you just choose number (location, user)..
              • pakobernal
                • May 2012
                • 46
                Thanks everyone for answering, it was finally hdd problem, I had to go and change it and the problem has been fixed.
