Ricoh MP201
  • QR Rebecca
    • Nov 2021
    • 2
    [Error Code] Ricoh MP201
    Good morning to all.
    I would appreciate his help.
    I have a problem with a Ricoh Mp201. There was a noise on the right door on the side of the fuser and it turned out to be the transfer roller gear. While testing, I closed and opened the door several times and one of those times I marked "remove the paper from the ADF" followed by "Error SC320 "
    According to the manual I must change the polygonal laser motor and / or the BICU.
    What would cause this failure, if it was okay at the time of checking?
    Thanks in advance.
    • 37560
    Re: Ricoh MP201
    Very common. Toner has built up in the bushings of the PTR and is causing it to not turn freely. As a result the teeth on the drive gear are jumping against the gear on the drum. Clean or replace the PTR.
    • GIUBOSS
      • 1437
      Re: Ricoh MP201
      Thanks in advance.
      Sc320 if I'm not mistaken when removing the toner housing it can give this code but sometimes even the motor with polygon mirror can fail.
      • QR Rebecca
        • Nov 2021
        • 2
        Re: Ricoh MP201
        Thank you very much, I will take your comments into account.
