Exit rollers MP C3003
  • menosmola
    • Apr 2014
    • 95
    Does anyone know why some machines have black paper exit rollers and others have white ones?
    This gallery has 2 photos.
  • luca72
    • Oct 2017
    • 1774
    maybe because before it had the bridge unit for the finisher mounted which was then removed, (photo on the left)...among other things I see that the door/cover of the bridge-unit connector is also missing, classic, because when the finisher is installed that cover usually ends up in the garbage, because it is no longer needed
    Unfortunately I can't see the enlarged photos well with this monitor I have, so I would assume that the shape of the rollers is also different
    "I'll be back"
      • 37477
      Most likely either a change in supplier or a cost reduction move. They look to be the pressure rollers so color is not that important. I have seen both black plastic and white plastic in other equipment.
