Horizontal big stripes
  • DanielGo
    • Mar 2021
    • 2
    Hi,
    we got a Ricoh Pro C5100s and got horizontal lines in cyan. I changed the cleaning blades and the drum but its not getting better. What could i be.
  • GIUBOSS
    • 1410
    Re: Horizontal big stripes
    Originally posted by DanielGo
    Hi,
    the charging unit? Also check the transfer. I would like to believe that you tried a color test with the other colors too ...
    • davel
      • Oct 2011
      • 1099
      More info needed, paper size, feed direction, have you changed charge roller, are you trained on this machine?
      • Drivee
        • Nov 2020
        • 322
        That is not OPC, it is a doctor blade. First try to fix with sheet of paper. Pull between DEV roller and Doctor blade, if not, take it off, clean with IPA and install.
        • davel
          • Oct 2011
          • 1099
          that would give a white/light line.
          • DanielGo
            • Mar 2021
            • 2
            All other colors are okay. Its in print direction. A ->
            • Drivee
              • Nov 2020
              • 322
              Not true. You have dirt in doctor blade and more toner coming on OPC then should be on that place, that is reason why line is darker then other print. If you rotate Dev, you will see that that place will have more toner on it. It is easy to check. Also, you will see that doctor blade is dusty on that place.
