Scanning large files to email
+ More Options
Posts
  • Mark Bbb
    • Jun 2012
    • 1662
    #16
    Re: Scanning large files to email
    batch transmission
    • copier tech
      • 8225
      #17
      Also set max email size from 2048 to OFF
      โ€‹
      • keithxxiii
        Just a tech
        • Nov 2014
        • 471
        #18
        Even if you set the transmit size of the MFP to higher size, if it is not allowed by the SMTP server, then it won't work.
        Aye! Cut the crap
          • 37631
          #19
          Originally posted by Mark Bbb
          batch transmission
          I believe that batch transmission is to allow mixing originals that are different sizes and/or a mix of both single and double sided originals.
            • 37631
            #20
            If the size is going to exceed 25MB, the input limit of most SMTP servers, you can always scan to a local folder and then use gmail which automatic uploads large attachments to Google drive and sends a link or manually upload to Dropbox and attach a link.
            • mikadonovan
              • May 2008
              • 2931
              #21
              Originally posted by Skieroney
              You may check this review: how to send a video through email. There are some tips on attaching media files to email.
              Your first post on this forum is to resurrect a thread that is nearly 9 years old
              NEVER ASSUME ANYTHING
              • Mark Bbb
                • Jun 2012
                • 1662
                #22
                Batch transm. = large amount of documents (more than feeder can handle in one time) sending in one file to your computer.
                Indeed, you can combine different original sizes or combine platen glass and ADF...
