SC 513-00 C7100SX
  • jujitsu47
    COPIER TECH SPECIALIST
    • Jun 2014
    • 20
    SC 513-00 C7100SX
    Happens intermittently no problem found.
    • 36884
    Something having to do with the cutter home position. Dirty or failing HP sensor, cutter binding, cutter motor, harness, IOB or roll feed board.
    • Leoculus
      • Jul 2024
      • 62
      SC513-00 D Registration Gate Position Error
      Home position on/off was not detected within the time limit.
       Gate Retract HP Sensor connector disconnected and
      defective
       Gate Retract HP Sensor disconnected and defective
       Defective operation due to overload
       Defective operation due to the motor driver defective
       Gate Retract HP Sensor shield deformed/broken/incorrectly
      attached
      Cycle the machine off/on.
      KB Number: KB0187223 KB use count : 1
      Resolution:
      Remove paper that was wrapped up from the area around the registration gate motor drive.
      KB Number: KB0175485 KB use count : 1
      Resolution:
      Reconnect the registration gate motor
