Ricoh IM C2000 ARM64
  • jeanpaul
    • Mar 2009
    • 117
    [Misc] Ricoh IM C2000 ARM64
    Hi to all, can someone help to install a print driver on a laptop windows 11 AMR64 for a Ricoh IM C2000.
    Rgds
    • 37408
    This might help. https://kb.gsd.ricoh.com/app/answers...-arm-processor
    • jeanpaul
      • Mar 2009
      • 117
      Hi. Thanks for the reply but my customer have access code on the Ricoh IM C2000, so the mopria print will not work
        • 37408
        You can add Enterprise Mobility Management (EMM) software does allow User and Account IDs for better oversight and accountability. See Workplace Features in the following.
        Mopria certification ensures seamless printing and completes the experience with connectivity to millions of certified printers from many manufacturers.
        Or you can just tell your customer that Windows Laptops with ARM processors are not compatible with standard print drivers. You can also search Printing from Windows PCs with an ARM processor and follow all the steps in the Microsoft support article which just might end up with you having to install Ricoh's rather expensive internal WiFi interface and hope that works.
        You might also be able to just enable Bluetooth on the laptop and the SOP and use that. The range is rather limited so the user will need to be near the IM C2000.
