converting a SP430 DRUM/DEV UNIT TO MPC401 DRUM?
  • fshead
    • 2376
    Greetings
    i have about 25 SPC430/SPC440 DRUMS THAT I WANT TO CONVERT TO MPC401 USE
    THOUGHT IT WAS JUST SWAPPING TD DEV UNIT SENSOR AND HARNESS..BUT IT DID NOT WORK??????
    THANKS IN ADVANCE
  • sandmanmac
    • 3981
    Re: converting a SP430 DRUM/DEV UNIT TO MPC401 DRUM?
    Hey Andy.
    Hope all's well. Don't seem to see as much of you around these parts lately?
    You have to swap 2 wires from the connector to to TD sensor.
    I figured out this conversion a few years ago created a document for myself, and also added it to some other conversions (Fuser unit) that someone else had posted previously.
    Have a look....
    SPC430 - MP C400.pdf
    • fshead
      • 2376
      hey SANDY
      HOWS the great north??
      I am just getting by as things are still not back to normal in nyc and i
      have focused more on rebuilding my home.
      And then my place upstate.
      so copier stuff takes a back seat for me now.
      Thanks for the info .
      I swapped out td sensor,complete harness,even the one with
      the 2 wires that would be swapped over.
      Maybe that drum was not a old mpc401 drum or
      maybe i put the td sensor back by accident.
      I will revisit today.
      I would assume one can take the sensor and connector from a color mpc 401
      and use it on a black spc430 drum/dev unit...
      Stay safe
      thanks
      • sandmanmac
        • 3981
        thanks
        That I can't tell you for sure. I think I only ever did this from black to black and colour to colour.
