MP 6000 SC672
  • orestesp
    • Sep 2019
    • 230
    MP 6000 SC672
  • MitchD
    • Oct 2012
    • 164
    Re: MP 6000 SC672
    I'm betting you will need a new control board. My experience with the 672 is almost always that, especially if you have already checked the DIMM's, HDD, ect....... Does it have a fax board? If so try to remove that and reboot.
    Good luck!
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
    • orestesp
      • Sep 2019
      • 230
      Re: MP 6000 SC672
      Just to check: is the highlighted cable the one that connects the opeartion panel to the controller board? I cannot seem to find any other cable harness that connects to the controller board.
      • KeviM
        • Oct 2019
        • 327
        Re: MP 6000 SC672
        From my experiences this code is 1 of these :
        1) RAM
        2) Hard drive
        3) Controller unit
        I would say try changing the RAM and Hard drive with 1s that you know are working before changing the controller unit.
        Also you can try (if you don't have another controller) disconnecting the controller unit and starting up (yes I know this is unorthodox) with the back covers off keep an eye out for lights and fans that may or may not come on.
        Also check for power coming into the controller unit .
        All the best friend. Hope this helps.
        • KeviM
          • Oct 2019
          • 327
          Re: MP 6000 SC672
          Also might be a faulty control panel. Try swapping with another
            • 37643
            Re: MP 6000 SC672
            First thing to try is to disconnect the HDD. If it then boots, the HDD is bad.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Re: MP 6000 SC672
              I agree with Slim.
              Disconnecting only the power to the HDD will do nothing, in fact, it will only cause a problem.
              Unplugging the data cable, on the other hand, will remove it from the equation completely, and may allow the machine to boot.
              • orestesp
                • Sep 2019
                • 230
                Re: MP 6000 SC672
                Originally posted by KenB
                I agree with Slim.
                I didn't think that this was possible, as I thought unplugging the molex power connector from the drive would simulate an absent HDD condition. I couldn't get the IDE cable unplugged from either end, given how cramped everything is but I will certainly give this a try tomorrow.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  • DRichard
                    • May 2008
                    • 482
                    Re: MP 6000 SC672
                    Disconnect any and all features in the back, including memory card(s), fax, HDD, etc. Yes you lose certain functions, but all you are looking for at that point is to see if that code goes away.
                    "Enjoy every sandwich."
                    -- Warren Zevon
                    • tsbservice
                      Field tech
                      • 8077
                      Re: MP 6000 SC672
                      On my Konicas when I suspect HDD I make it unset in service mode followed by physical removal of data and power cables from HDD just to make triple sure machine has no any clue about HDD
                      In that process I usually lose more time to remove covers over HDD than other operations.
                      • copier tech
                        • 8236
                        Re: MP 6000 SC672
                        The MP 6000 is too old now however if you want to try a firmware update feel free to contact us.
                        • orestesp
                          • Sep 2019
                          • 230
                          Re: MP 6000 SC672
                          Disconnected both the HDD completely and then the NIC/USB card (no other expansion cards are present, such as the FAX card which could cause this cause if the jumpers are set incorrectly) but no change.
                          I will try to find two different sticks of RAM to try it with, but I am afraid we are headed towards replacing the controller.
                            • 37643
                            Re: MP 6000 SC672
                            Is there a possibility that someone may have removed a SD card such as the JAVA card without properly stopping JAVA? If so, the controller board is cratered.
                            • orestesp
                              • Sep 2019
                              • 230
                              Re: MP 6000 SC672
                              I am 100% certain that absolutely no one has messed with the SD card, or the machine in general. The last time anyone has touched it was a couple of months ago when I did some PM work on it. It's a classic case of "it worked just fine the day before".
                              I just removed the cover from the SD cards, blew some air into the contacts on the motherboard (they were clean but you never know) re insterted them in the same position as they were as well, nothing again. Also I am 100% sure both sliders on the SD cards were in the original position as they where when the machine was working.
