MP 6000 SC672
  • tsbservice
    replied
    Re: MP 6000 SC672
    First thing to try is to disconnect the HDD. If it then boots, the HDD is bad.
    On my Konicas when I suspect HDD I make it unset in service mode followed by physical removal of data and power cables from HDD just to make triple sure machine has no any clue about HDD
    In that process I usually lose more time to remove covers over HDD than other operations.
  • DRichard
    replied
    Re: MP 6000 SC672
    Originally posted by orestesp
    I didn't think that this was possible, as I thought unplugging the molex power connector from the drive would simulate an absent HDD condition. I couldn't get the IDE cable unplugged from either end, given how cramped everything is but I will certainly give this a try tomorrow.
    Disconnect any and all features in the back, including memory card(s), fax, HDD, etc. Yes you lose certain functions, but all you are looking for at that point is to see if that code goes away.
  • KenB
    replied
  • orestesp
    replied
    Re: MP 6000 SC672
    Originally posted by KenB
    I agree with Slim.
    Disconnecting only the power to the HDD will do nothing, in fact, it will only cause a problem.
    Unplugging the data cable, on the other hand, will remove it from the equation completely, and may allow the machine to boot.
  • KenB
    replied
    Re: MP 6000 SC672
    I agree with Slim.
    replied
    Re: MP 6000 SC672
  • KeviM
    replied
    Re: MP 6000 SC672
    Also might be a faulty control panel. Try swapping with another
  • KeviM
    replied
    Re: MP 6000 SC672
    From my experiences this code is 1 of these :
    1) RAM
    2) Hard drive
    3) Controller unit
    I would say try changing the RAM and Hard drive with 1s that you know are working before changing the controller unit.
    Also you can try (if you don't have another controller) disconnecting the controller unit and starting up (yes I know this is unorthodox) with the back covers off keep an eye out for lights and fans that may or may not come on.
    Also check for power coming into the controller unit .
    All the best friend. Hope this helps.
  • orestesp
    replied
    Re: MP 6000 SC672
    Just to check: is the highlighted cable the one that connects the opeartion panel to the controller board? I cannot seem to find any other cable harness that connects to the controller board.
  • MitchD
    replied
    Re: MP 6000 SC672
    I'm betting you will need a new control board. My experience with the 672 is almost always that, especially if you have already checked the DIMM's, HDD, ect....... Does it have a fax board? If so try to remove that and reboot.
    Good luck!
  • orestesp
    started a topic MP 6000 SC672
    MP 6000 SC672
