IM C2500 not recognising toner after firmware update
  • dave w
    • Jun 2015
    • 230
    Hi all
    Has anybody come across the problem with a IM C2500 saying = print Cartridge Setting Error = after a remote firmware update?
    Was there for a fusing unit ghosting problem and after the fix started off the remote firmware update (left the office as they wanted to close it) left the machine to do it magic!! - after the update the error started !
    was working fine before.
    going back tomorrow with another toner (Ricoh toner)
    Any ideas in advance of my return?
    Thanks Dave
  • 8T2
    • Aug 2015
    • 257
    Re: IM C2500 not recognising toner after firmware update
    Think it's just by chance that toner not set message came up after doing firmware because I've been running into this issue way too much recently. Check the chip contacts on the toner bottles. Chances are you'll see one of them is contaminated. Don't know how many I've had to literally scrape clean with a small flat the past year or so
    Sent from my SM-A305F using Tapatalk
    • dave w
      • Jun 2015
      • 230
      BIG Thanks 8T2 for reply.
      Yes I was thinking pissibly chip contamination, Will see tomorrow
      Thanks again
      Dave w
      • GIUBOSS
        • 1436
        Originally posted by dave w
        Hi all
        Thanks Dave
        Is the installed toner genuine?
        • dave w
          • Jun 2015
          • 230
          Yes
          funny you should ask as the colors are not, only the K toner is genuine.
          If it was the other way ( not seeing the non ricoh toners ) then I would be thinking about richo may of done something to the FW to detect non ricoh toners.
          • tsbservice
            Field tech
            • 8020
            "print Cartridge Setting Error" means no K toner? Strange.
            Of topic
            Are you sure using compatible toners CMY is OK long term wise? Maybe ghosting problems aren't coincedense.
            • dave w
              • Jun 2015
              • 230
              Hi
              My thought pattern was that sometimes a firmware update will adj a Fusing issue. (goes to show - poxy firmware updates - if its not broken dont fix it! )
              After removing lots of paper dust from ITB due to cheep paper and removing some baked toner from the guide all was ok, 50 copies and no issues.
              small office and and under 10K on use.
              will see today when I revisit.
              Thanks all
              Dave w
              • dave w
                • Jun 2015
                • 230
                Quick update while im on site
                When all the color toners are removed it recognises the K toner , all color tones are now Ricoh.
                I have checked the contacts from above via removing the plastics that cover it, all clean and no visible breaks.
                the ricoh update tool says the firmware is up to date, now going to see if there is a roll back.
                Dave w
                update
                Does not look like a roll back is possible and all is up to date.
                Update
                Just been advised from Ricoh Tech to backup nvram - then clear nvram to see if toners are recognised. before I do that all the toners are going back to the office to see if they work in our machine first.
                Dave w
                • emiliorsg
                  • Jul 2018
                  • 141
                  Have you checked that the firmware version is the latest one published in octopus? The latest version of the package is v4.60.1You can also try to re-install the same version with the sd card.
                  • dave w
                    • Jun 2015
                    • 230
                    Hi emiliorsg
                    Yes i did check and was all up to date.
                    • dave w
                      • Jun 2015
                      • 230
                      NEW UPDATE
                      I removed all 4 toners from the customer and placed them in a new IMC2000 we have here in the workshop.
                      Same issue, so has to be the toner chip. SPOOKY
                      new set of toners have been ordered and hopefully that will do it.
                      Thanks all
                      Dave w
                      the big question is why? and after a firmware update. Lets hope that was a one off case.
                      • TonerMunkeh
                        Professional Moron
                        • 3865
                        It's just one of those stupidities. I had an MPC3003 that the side door harness was replaced on due to jam 024. When the harness was replaced, it threw a really odd and spurious code that turned out to be one of the toner bottles. Put the old harness back on and it worked fine.
                        Hit it.
                        • UNICORNico
                          • May 2018
                          • 308
                          Compatible or Original Toners, if the chip is not read correctly causes rare errors in some machines.
                          I had a similar problem in an MP C5502, the connector of the Cyan chip, had the tabs crooked, causing a strange "short", and the machine indicated that the Image Units (all) and the Fusion Unit, were not installed correctly.
                          "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                          • Gift
                            • Mar 2011
                            • 2459
                            That NV Ram clear method helped me several times with the older series but good to know it was the chip (better that than a faulty contacts inside the MFP we had a lot with the MPC305 back then).
                            • dave w
                              • Jun 2015
                              • 230
                              To be honest - I have never done a NV Ram Clear and used a Birth Sheet to re input all the details, so i was relieved to see it was the Toner chip. PHEW!
