IMC3500 turning copy page 180 degrees
  • GeorgeBest
    • Jul 2009
    • 517
    When making a copy on the ADF the image is turned 180degrees, this is not standard is it ?
    can't see where to adjust this
    Putting an original on the glass, its not twisted
    someone?
    thanks in advance
    gr G
  • dalewb74
    • Feb 2018
    • 1125
    Re: IMC3500 turning copy page 180 degrees
    how does the users guide say to change it???
    • GeorgeBest
      • Jul 2009
      • 517
      Don't see that,
      strange, because sometimes it works allright
      making a scan, it doeas'nt turn
      • Mark Bbb
        • Jun 2012
        • 1662
        Zelfs in het beschaafd Nederlands, als dat geen goede service is!
          • 37052
          What size and orientation paper was available? A machine with a tray set for LT SEF and one set for LT LEF will auto rotate if the tray with the same orientation of the original is out of paper.
          • ABS tect
            • Sep 2013
            • 511
            Originally posted by GeorgeBest
            someone?
            thanks in advance
            gr G
            Are you saying from the ADF it is rotated, but from the platen glass it is correct? Or they both mess up? Essentially printing portrait on landscape or visa-versa.
            Check that you have auto-detect turned on for page size when scanning...or make sure that auto-select is on for which paper tray it pulls from.
            If you only ever scan in one orientation, you can program it for SEF or LEF always and make both your trays set with the same orientation to avoid that.
            Assuming all that is done...could be that if this is only happening from the ADF that one of your original width detection sensors is out..which can be checked in the periphs (input check)
            • Mark Bbb
              • Jun 2012
              • 1662
              • GeorgeBest
                • Jul 2009
                • 517
                turned out te be the settings in the copier document system settings.
                "letterhead" setting was Off . . .
                thnx for replies
