Mpc306 void lines
  • dankaboy
    • May 2010
    • 14
    Mpc306 void lines
    Anyone had these juddering noise type void lines on all colours. I've fitted ITB and PTR assy's with no joy.
  • copier tech
    • 8222
    Re: Mpc306 void lines
    Still looks like a fuser issue.
      • 37628
      I would suspect a roller whose diameter is a multiple of the distance between the voids. Or a gear somewhere causing a jitter in the movement.
      • dankaboy
        • May 2010
        • 14
        I'll pop one in tomorrow.
        Sent from my SM-G525F using Tapatalk
        • RMC8112
          • Nov 2019
          • 38
          Looks like a transfer roller issue. I would check the contacts for the PTR, also the shaft for any dirt that will prevent contact. check for cracks in the roller foam. i had an issue like this and when i check the roller, it had a tear in the foam.
          • Gift
            • Mar 2011
            • 2459
            Are these voids also visible on the image when it's on the transfer belt - just interrupt the print process and check.
            • dankaboy
              • May 2010
              • 14
              Looks perfect on the belt and changed the Transfer roller.
                Was it a new xfer roller or used?
                • dankaboy
                  • May 2010
                  • 14
                  Brand new PTR. I've ordered a full set of drums and fuser(over kill and probably non related). Going back in with another engineer as I'm going round in circles. Will be a bent spring or something silly like that.
                  • UNICORNico
                    • May 2018
                    • 308
                    It reminds me of a failure of an IM C4500, ha which changed the Transfer Band badly, and placed it upside down.
                    I had to disassemble the entire Transfer Unit to place the mark in the correct position for installation.
                    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                    • Maged_elagamy
                      • Mar 2021
                      • 42
                      agree
                      it's a fuser problem i think
                      check fuser belt or may be loose spring
