ricoh sp c242 error c300
  • Gab
    • Aug 2015
    • 670
    How can i reset this error code and if does not work where is the problem ?
  • davel
    • Oct 2011
    • 1097
    Refer to your service manual
    • Gab
      • Aug 2015
      • 670
      If i had service manual i would not asked.
      • Larhal
        • 565
        • Code: 300
        • Description: High voltage power output error
          The measured voltage is not correct when the EGB measures each charge output (charge, development, image transfer belt unit, and transfer unit).
        • Causes Disconnected or defective high voltage harness. Defective high voltage power supply. Defective EGB.
        • Remedy:1. Check or replace the harnesses. 2. Replace the high voltage power supply board 3. Replace the EGB.
        Larhal
        If all else fails read the Service Manual!
        If that fails, meet me at the pub and we will discuss it.
