Hi guys,
Bit of a strange one, which has left me feeling rather defeated.
Customer has a Ricoh imc4500 with booklet finisher, which refuses to staple and fold booklets (A3 & A4) when printing documents from any application. If you choose to just fold and no centre staple it works fine, only when you ask it to staple and fold it cancels the job out completely. Under job history it just says deleted due to error with no explanation.
Both trays set to plain paper.
Setup using TCP/IP. Print configuration is correct with all the correct options selected/detected.
Tried printing same documents direct from usb stick with same issue.
The strange thing is that it copies fine with staple and fold!
Iv updated the machine and finisher to the latest firmware.
Tried every print driver available on Ricoh's site.
Tried it from my own laptop same result under windows 11.
Any ideas would be greatly appreciated as it's been on going for quite some time now. And like most things, was never an issue to begin with.
