Greetings to you all, i was called by a customer that his mpc3004 has the moistured and almost faded color pattern. So far, I've changed ITB and ITB Transfer Roller yet no solution. Attached is the sample.
FAINT TEST COLOR PATTERN ON RICOH mpc3004
This gallery has 1 photos.Tags: None -
PCDU have all been changed, still no luck. Concerning posting twice it was due to service provider mishaps.Comment
Run a duplex copy or print & see if the 2nd side the quality has improved.
👍 2Comment
From the sample print, it is understood that;
The paper is damp
The laser protective glass is dirty
There is sedimented toner or other foreign substances in the developer unit
Also, check if the right side cover is closed properly. Check the position of the transfer roller unit.👍 2Comment
The paper is damp
Also, check if the right side cover is closed properly. Check the position of the transfer roller unit.Comment
