hostname like RNP5838794BDxxx changing to f.i. the name of enterprise
  • Mark Bbb
    • Jun 2012
    • 1662
    Is this possible?
    I have tried this on our imc2000, but it says: "wrong parameter".
    A customer asked if it was possible to change this number to the name of his enterprise.
    So his customers would see the name of his enterprise in the sended scan.
  • 8T2
    • Aug 2015
    • 257
    Re: hostname like RNP5838794BDxxx changing to f.i. the name of enterprise
    Will work but no spaces or special characters allowed
    Sent from my SM-A305F using Tapatalk
    • Gift
      • Mar 2011
      • 2459
      I'm quite shure you can edit the entire subject line for scan to mail function, perhaps you can also edit the file name parameters somewhere.
      • 8T2
        • Aug 2015
        • 257
        This is indeed another option.
        • Mark Bbb
          • Jun 2012
          • 1662
          Even when we increase the hostname number with 1, so xx62 -> xx63
          "Wrong parameter"
          I think it is impossible.
          • rthonpm
            • Aug 2007
            • 2859
            It just uses whatever is configured as the hostname of the machine. Keep in mind you have a 15 character limit with only letters and digits available.
            You could also have them use an email address that is part of their actual organisation so that whatever visible name is configured on their mail server will show as the sender.
            Sent from my BlackBerry using Tapatalk
