Ricoh IM C3000 Newbie in the Boonies = Self-Repair SC362-01
  • Tigerlily
    • May 2025
    • 8
    Originally posted by sandmanmac
    With that information, I'd say it was not working when it got wrapped in plastic, and likely had a more serious issue that they opted not to fix.
    Bottom line is that if it was a known working machine to start , troubleshooting steps have a direction.
    Since it was not, and you are not an experienced tech, it's a crap shoot.
    Without having access to known working parts to swap around, it's VERY difficult to suggest much more than already has been.
    I personally feel that you may have a bad BICU board (I hope I'm wrong).
    I built my own computer from scratch in 1988. I have been working in and around computers all my life. If it is simply replacing a controller inside, I can do that. A quick search indicated the Boards are about $100. Is that correct? I don't have the manual with me, but I will look at that tomorrow.
    How do I narrow down whether that is the problem, or not?
    • sandmanmac
      • 3973
      Here we go.......
      I bet Bill Gates can't fix a copier either.
      IT may well not be a board.
      That's the thing.
      You got a machine out of basically a junk heap that didn't work, and want others to look into a crystal ball and fix it.
        • 37027
        More like $450.00 for the BICU
        • Tigerlily
          • May 2025
          • 8
          #19
          Thank you all for your help!
