Ricoh mp 501 low print quality on solids
  • omorales
    • Mar 2015
    • 86
    Hi friends, I'd like to know if there's any way to improve the MP501's quality on solid paper.
    It has a new imaging unit, the development unit is fine, and I don't have any other equipment for testing.
    Additional toner was added and the drum was shaken.
    The charge was adjusted, but the quality did not improve.
    The toner density was increased by 2 points.
    None of this improved the quality, especially on solid paper.
    NOTE: The character print is correct.​
  • luca72
    • Oct 2017
    • 1791
    try cleaning the laser, and its various glasses
    if it does it again I would try another development unit​
    "I'll be back"
    • MIGUELMARCHENA
      • Feb 2018
      • 195
      Lower the development unit and disassemble it, discard any toner inside, and thoroughly clean the magnetic roller.
      Assemble and add original toner.
      While removing the charge roller, clean or wash it. Disassemble the imaging unit and vacuum out all the toner inside.
      How many copies does the machine have? It could also be a cylinder that's about to die.​
      • omorales
        • Mar 2015
        • 86
        Scan attached.
        Finished cleaning the laser, replaced the fuser.
        Has a new imaging unit.
        Cleaned the development unit.
        Removed the toner from the development unit, installed a new one.
        Doesn't seem to be getting better.
        • luca72
          • Oct 2017
          • 1791
          Scan attached.
          nothing remains but the transfer roller
          "I'll be back"
