MP C6503 SC381-01 to SC381-04
  • alaa1005
    Old Member
    • Jul 2011
    • 8
    [Error Code] MP C6503 SC381-01 to SC381-04
    Hi All,
    Hope you have a great day! I have Ricoh MP C6503 in the field that consistently displays SC 381-01 to SC 381-04 errors every morning upon first use. The error clears after the customer power cycles the machine, and it works fine all day. Tried replacing the potential sensor board and potential sensor with no luck. Has anyone faced this issue before, or have any ideas how to solve this? Thank you!
    • 37524
    What are the maintenance counts for the drum units? What is the overnight temperature and humidity in room where the C6503 is located? Condensation on the surface of the drums can adversely affect potential sensor readings.
    • alaa1005
      Old Member
      • Jul 2011
      • 8
      The below are machine condition. the machine counter is only 80K.
      Body: Temperature [degC] SP3261-001 24
      Body: Humidity [RH%] SP3261-002 45
      Body: Abs Humidity [g/cm3] SP3261-003 9.81
      Color Usage
      Total Click SP8581-001 79,869
      Total Click: Full Color SP8581-002 16,407
        • 37524
        IF your C6503 has only 80K on the counter then there in lies the problem. That model was replaced five years ago by the IM C6500. No new MP C6503 were produced after that time. Every consumable in the PCDUs has died of old age.
        • alaa1005
          Old Member
          • Jul 2011
          • 8
          yes, it was old stock, but it installed one year ago, and this error appear since tow month only. The machine sometime work for tow week without any problem.
          • luca72
            • Oct 2017
            • 1783
            Originally posted by alaa1005
            Hi All,
            Run SP3070 and execute to run potential control
            Run SP3071-01 to see the reading for step 1. If number is -550 or more negative then drum and potential sensor are good.
            run SP3030. This will stir developer mix and will run for a couple of minutes
            Power cycle printer and run test copy. If good you are done. If the image is light run SP3050-01 to force add toner. Run SP3030 power cycle and check image. Repeat if necessary.
            "I'll be back"
