Ricoh im c6000 - loud noise near fuser unit
    • 37584
    One thing to consider when running a motor test for noise, if one or more clutches need to be energized to put the full operational load on the motor you may not get the noise.
    • Gift
      • Mar 2011
      • 2459
      +1 for pressure mechanism and +LOL for camel fart
      • EzSkeez
        Office/Pro Technician
        • Jun 2023
        • 13
        I found the issue with the intermittent noise. It was caused by the paper support guide in the bridge unit being slightly out of position and hitting the drive rollers.
        After correctly seating the plastic guide plate, the noise has not occurred since
          • 8198
          #19
          Run output check for each motor don't run the whole machine!
          • EzSkeez
            • Jun 2023
            • 13
            #20
            The machine was upgraded to an IM C4510 series.
            I brought the (MFD) back to replicate the noise, but I was unable to do so.
            When I tried to slightly remove the paper guide plate in the bridge unit, it would jam. I attempted various methods to make the noise reoccur, but nothing worked.
            The machine has since been refurbished and installed at another site, and there have been no issues.
            Ultimately, the source of the noise remains a mystery.
            • driving lots of miles
              • Jun 2016
              • 403
              #21
              I had this same exact issue on a new sharp bp mono machine and was unable to resolve it on site and we did exactly as you did. No noise when we brought it back and refurbished and installed at another site, and there have been no issues. We ended up calling it a transport vibration adjustment.
