SC672
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    SC672
    Hello colleagues, I have a PRO1357EX with the SC672 fault. it came out suddenly and I can not solve it, as the manual is very terse. does it sound to any of you the possible cause? Thanks!
    Field technician since 1994
    • 37471
    Re: SC672
    From Goose's Guide
    Controller startup error - reseat memory dimms or replace
    Controller startup error - disconnect HDD's..
    Controller startup error - Controller defective
    Controller startup error - Op panel harness or connections defective
    Controller startup error - Check CN31 on controller with BICU.
    Controller startup error - Reseat connections on IOB.
    Controller startup error - update system fw to 2.09 or higher
    • davel
      • Oct 2011
      • 1103
      Re: SC672
      Probably needs new controller board.
      • sandmanmac
        • 3981
        Re: SC672
        Agree with Davel, that it could very well be the controller board, but PLEASE search the site -there are DOZENS of threads relating to SC672 on all different models. It's one of the most frustrating and wide ranging errors there is.
        Start with some of the solutions Slim has provided and go from there
          • 37471
          Re: SC672
          I had it with a 1357 many years ago. I actually had to use Tera Term to pull function data directly from the controller and submit it through the West Coast Regional rep to the product engineers for help. I can't remember exactly what it was but it turned out to be something that was intermittently not energizing properly.
          I have learned that any component, like a motor or solenoid, that pulls too much current when energizing can cause error codes totally not associated with the device itself. Things like a shorted toner dispensing motor causing stacking errors in the main stapler. Found that when I noticed that the test checker flags I was running while watching the stapler were starting to fade. Disconnected the motor and the problem finisher problem went away.
          • DRichard
            • May 2008
            • 482
            Re: SC672
            From Goose's Guide
            ...or something else.
            "Enjoy every sandwich."
            -- Warren Zevon
            • elmaligno
              • Oct 2009
              • 302
              Re: SC672
              Update: the bug was the Controller Board...luckily I was able to repair it
              • TonerMunkeh
                Professional Moron
                • 3865
                Re: SC672
                Share your Godly board repairing knowledge with us...
                Hit it.
                • anothertech
                  • 1768
                  Re: SC672
                  Yes, tell us how you repaired the board.
                  • Zaxxon
                    • 608
                    Re: SC672
                    Apparently not, hit and run member.
                    Please start you post with brand, model, problem.
