Ricoh MPC 3500 SC552 error
  • tibbs
    • Aug 2008
    • 225
    Hey guys i have a ricoh MPC 3500 with an error code SC552, am not sure what the problem is and how to clear it.But the last time i took out the fusing unit and it cleared but it came back again.Can anyone share some information on this problem or anyone with similar problems.
    Thanks much
    Tibbs
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Heat roller thermistor (accessed from the bottom of the fuser).
    Either it's faulty, out of position (make sure it's in contact with the roller) or it may just be clogged up with toner and need a clean.
    SP5810 to reset.
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      Reset it using tech mode. Observe 1-106 temp settings while machine is warming up. Could need a heat lamp, thermistor or thermal fuse.
      • tibbs
        • Aug 2008
        • 225
        Thanks much friends there was a toner buildup on the hot roller thermister. Cleaning it solved the problem.
        • Johnboy
          • Mar 2010
          • 8
          Ive had this problem in the past, changed thermistor and the lamp, it re-curred after speaking to Ricoh a fuser replacement is recommended.
