IMC3000 with OCR scanning
  • GeorgeBest
    • Jul 2009
    • 517
    Customer ordered a OCR unit, installed this last week.
    Now I get the question from customer:
    " can I scan directly to an PDF/A-2a, PDF/A-2u, PDF/A-3u and PDF/A-3a format " ??
    I think that they need special software to convert ?
    But need the OCR for making the surchable file (?)
    Thanks in advance
    • 37059
    Re: IMC3000 with OCR scanning
    There is an Administrator setting in User Tools for turning PDF/A On/Off.
      • Settings screen type: Standard
        [System Settings][Settings for Administrator][File Management][PDF File Type: PDF/A Fixed][On]
      • Settings screen type: Classic
        [System Settings][Administrator Tools] tab [PDF File Type: PDF/A Fixed][On]
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3945
      In other words, you choices are limited to what Slim graciously mentioned above; nowhere near the number of options the customer is asking for.
