IM C3000 background with 2 thin white lines . . .
  • GeorgeBest
    • Jul 2009
    • 525
    Hi,
    Got an IMC3000 that print in black modus some background with 2 thin white lines, thers is text however in those white lines . . .
    Proberly the developer unit K thas has to be changed? Density adjustment doesn't help. . .
    someone?
    Thanks in advance
  • bobbygamba
    • Mar 2025
    • 1
    check the magnetic rollers and then go to engineer mode and do manual procon...think it will help
    • davel
      • Oct 2011
      • 1097
      Sample would help.
      • luca72
        • Oct 2017
        • 1752
        Originally posted by GeorgeBest
        Hi,
        someone?
        Thanks in advance
        clean laser glass, and with the developer unit removed from the pcu, turn the developer gear back and forth with your fingers several times, making it do a couple of turns each time, probably if the problem is there, you will solve it
        "I'll be back"
