Aficio SP 4310n Paper Size Mismatch In Tray 1 Error.
  • saibajustica
    • Mar 2018
    • 20
    Hey folks,
    I'm trying to print 8 1/2" x 11" from Tray 1 but keep getting the following error on an Aficio SP 4310n:
    Paper size mismatch in Tray 1. Change Paper. 5 1/2" x 8 1/2".
    I've changed the paper size settings, no go. Followed other troubleshooting suggestions in the hardware manual, but again, no go.
    Is there some configuration that I'm missing. Do I need to do something in service mode?
    Thanks in advance.
  • 8T2
    • Aug 2015
    • 257
    Re: Aficio SP 4310n Paper Size Mismatch In Tray 1 Error.
    What size is loaded in tray? What paper size is the document on PC?
    If it's a dirty paper size sensor or faulty tray detecting incorrect size on printer you can try manually setting paper size in user tools to match the paper loaded.
    If the printer is detecting the correct size paper that's loaded change the paper size of document on PC
    Sent from my SM-A305F using Tapatalk
      • 37628
      Originally posted by saibajustica
      Hey folks,
      Thanks in advance.
      Where are you changing the paper size setting at, the dial in the paper tray, the control panel (requires that the dial is set to *) or in page format for what is being printed? Paper size mismatch means that the size set in the printer does not match the page format setting for the document. And if I remember correctly the 5 1/2" x 8 1/2" indicated the paper size the computer is requesting.
      • davel
        • Oct 2011
        • 1108
        Document size is probably 5 1/2 x 8 1/2
        • saibajustica
          • Mar 2018
          • 20
          OMG! I'm such a newb!
          I didn't know there was a dial in the tray to adjust the paper size. That was the issue. It's all resolved now. Btw, I was trying to adjust to a paper size of 8 1/2" x 11".
          Thanks guys for all your help and patience. My learning journey continues...
