BLue Dusting on RIcoh SPC 360SFNw
  • BobbyZ
    • Jul 2025
    • 5
    I just replaced cyan cartridge with genuine part and I am still getting this. I have only used Ricoh toner in the lightly used MFC
  • luca72
    • Oct 2017
    • 1792
    I don't see the print copy example, but from the title I deduce that you have a cyano background (?)...it will almost certainly be the cyano pcdu, specifically the dirty charging roller, strange because usually that machine warns you much earlier to replace the pcdu compared to how much they are consumed
    "I'll be back"
    • BobbyZ
      • Jul 2025
      • 5
      I'm just an end user, so I dont know all that much about laser printers. I took the drum unit out and saw that cyan toner was on the drum at the end causing the problem, I used a microfiber and isopropanol and gently wiped the drum across itself and gently rotated the drum and continued until it was clen. I reassembled everything and tried a test print and it was a little better, by the second print returned with the same problem. The MFU is lightly used. and probably about 6 or so years old. Thanks for your help.
      • davel
        • Oct 2011
        • 1108
        Time to get a new C PCDU
        • BobbyZ
          • Jul 2025
          • 5
          Bummer, I thought it would last longer then 1900 pages
            • 37626
            With just over 2500 pages on a discontinued model that was introduced in 2018, I would say it might need all four PCDUs replaced.
            • BobbyZ
              • Jul 2025
              • 5
              So, it's just an age related situation?
                • 37626
                Age and under utilization.
                • BobbyZ
                  • Jul 2025
                  • 5
                  thanks I appreciate everyone's help.
