Lines on MP 501
  • mikadonovan
    • May 2008
    • 2931
    Lines on MP 501
    Hey All. Hope everyone is well. I have a bunch of MP 501's that are getting horizontal lines on solid areas. It kinda looks like a charge roller issue, but alas it is not. PCU, charge roller have been replaced, and the issue remains. Am I looking at a dev unit issue? I am not very familiar with this model. Thanks, Mika
    NEVER ASSUME ANYTHING
  • luca72
    • Oct 2017
    • 1791
    Re: Lines on MP 501
    hi Mika, the white lines you mean, are the big, clear ones? or the small ones that can be glimpsed in the black?
    "I'll be back"
    • mikadonovan
      • May 2008
      • 2931
      Re: Lines on MP 501
      This might be a better pic (jpg). Image is an 11% black, so it should be solid light gray. They are white lines about 5 mils apart across the entire image. This image prints ok to other machines.
      • luca72
        • Oct 2017
        • 1791
        Re: Lines on MP 501
        it seems a problem of the development unit, try to turn it a little forward, and a little back several times...and if metal, try to rub well throughout the surface, the magnetic roller with piece of paper to dry your hands, (the one a little rough), rotating it in the direction where it remains without toner attached.... check also the metal conctact.
        I must say that it will be my monitor, or I am blind, or because I am colorblind, but I do not see the lines!...I trust the description...LOL
        "I'll be back"
          • 37560
          Re: Lines on MP 501
          Are the lines parallel to or perpendicular to the direction of paper feed. Personally I do not like full bleed test prints as they are susceptible to some many fill problems. What I prefer if the Checker Flag test pattern.
          • mikadonovan
            • May 2008
            • 2931
            Re: Lines on MP 501
            Ok, on this jpg of a test print, look at the grey area at the top underneath the black area. It is a pretty good representation of the issue occurring over all of it. The vertical white lines are part of the test pattern. The issue is the horizontal lines (perpendicular to paper feed). PS, I really don't like these machines. Yea! you can actually see them on this one.
            • luca72
              • Oct 2017
              • 1791
              Re: Lines on MP 501
              Seem a defect of hvt board, or ipu, or also laser
              can generate a similar defect
              You reamain ti take another mp501, and change part since to isolate the problem
              "I'll be back"
              • mikadonovan
                • May 2008
                • 2931
                Re: Lines on MP 501
                I gave the mag roller a good scrub with a piece of paper, no joy. Development units are on order.
                • luca72
                  • Oct 2017
                  • 1791
                  Re: Lines on MP 501
                  You reamain ti take another mp501, and change part until to isolate the problem
                  "I'll be back"
                  • luca72
                    • Oct 2017
                    • 1791
                    Re: Lines on MP 501
                    let me know, when fixed... I was intrigued by this defect.
                    "I'll be back"
                      • 37560
                      Re: Lines on MP 501
                      THe impression I get is a lot of small toner clots in the development unit that are momentarily blocking the doctor blade and then clearing out only to work themselves back around. I have seen that happen when the machine gets too cold over night and condensation occurs in the PCDU. If anti-condensation heaters are available, install them before replacing the developer to prevent future problems.
                      • mikadonovan
                        • May 2008
                        • 2931
                        Re: Lines on MP 501
                        These are all off lease units, probably stored in a cold warehouse, and then transported in an unheated box truck from Dallas.
