Hi, I have a strange issue with using mixed media on a c7200/ Fiery E-45A with SR5060 finisher, and I'm wondering if anyone can shed any light on it ...
I've checked that the driver is the latest version.
I'm trying to print an A5 booklet which consists of interior pages 80g fed from tray A (weight 2) and a pre-printed cover 250g (weight 6) fed from tray 4 set to pre-printed paper.
When asked to print, the 80g pages print fine, then a cover sheet is fed from tray 4 but it just stops in the middle of the machine before entering the fuser. I've tried this numerous times, always with the same result. If I replace the pre-printed cover with a blank sheet of 250g it passes through correctly and the booklet is finished as it should be ... but with a blank cover of course ! I've also repeated this test several times, and a blank sheet always works.
Has anyone else experienced this issue ??
Any suggestions would be welcome ....
