SC-60-20-01
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    SC-60-20-01
    Dear colleagues, I have a SC620-01 fault on a PRO1357EX, but the ADF is not used by the customer, he only uses the machine as a printer... can I disconnect the ADF in any way to avoid a fault, apart from disconnecting the connection cable?
    Thank you!
    NOTE: THE CORRECT CODE IS SC620-01
    Field technician since 1994
