MP2851 Toner Supply Unit not available?
  • copyaction
    • Oct 2007
    • 991
    • 37557
    Re: MP2851 Toner Supply Unit not available?
    You should also be able to use the one for the 52s and 53s, D120 3503.
    What is the problem that you need to replace one? Usually you can just replace the individual parts.
    • copyaction
      • Oct 2007
      • 991
        • 37557
        Sounds like the Mylar sheets that push the toner to the exit have come loose. I don't know if they are still available. I had to go back to the Aficio 250 parts catalog to find their number, G020 3325 Sheet - Agitator. You may have to replace the D1203562 COVER:TONER BOTTLE:CTYPE:SUB-ASS'Y
        • rthonpm
          • Aug 2007
          • 2859
          Didn't Ricoh issue a bulletin about removing the individual parts for the hopper from the parts catalogue due to continuing issues with toner dumping?
          Also, there must have been additional updates to the hopper as the last ones I ordered arrived with part number D1203505.
          I have successfully used the hopper for this series in machines going back to at least the 2027.
          • luca72
            • Oct 2017
            • 1791
            if this is your problem, you can order the following parts, usually when you pull down the handle, and you see the puff, just replace the "slider" and the "chuck", if you have unglued the mylars, you can eventually recover the material from some old ADF guide, and by cutting out, you can cut out the unglued lugs that says slimslob, then you screw them to the support with very small self-tapping screws, it works great, I've done it a lot of times
            7 B090 3573 Slider:Ass'y 1
            8 B090 3571 Chuck:Bottle 1
            9 B090 3560 Cover:Toner Bottle:Ass'y
            "I'll be back"
            • emiliorsg
              • Jul 2018
              • 141
              We have always changed the parts indicated by Luca and solved it. It is true that it seems that there is no stock of some parts.
