DD 3344 Out of ink
  • Marwanalhajbi
    • Jul 2018
    • 72
    DD 3344 Out of ink
    dear all.
    i have Ricoh DD3344 i have an issue with the ink ,it says out of ink,however i changed the ink,filter,pump and clean the tunnel nothing worked,
    any suggestion please
  • mikadonovan
    • May 2008
    • 2931
    Re: DD 3344 Out of ink
    Sounds like a fault with the drum ink sensor.
    C261 2471 Ink Sensor: Ass'y
    NEVER ASSUME ANYTHING
    • usta
      • Oct 2013
      • 44
      board change
      • GIUBOSS
        • 1436
        Originally posted by Marwanalhajbi
        dear all.
        Are you sure the ink is being pumped and coming into contact with the sensor?
        • DH1980
          • Mar 2009
          • 52
          Try running the pump by hand. If that works take the sensor with the prongs off of the drum and clean it.
          After that it could be board.
