Ricoh Aficio 240w, I need parts!
  • bellsysoffice
    I am looking for a Ricoh Aficio 240w network card and a 240w controller. Any chance of knowing where to get one?
    Thank you,
    Rebecca
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Your nearest Ricoh dealership?
    Hope you have deep pockets though, the print/scan interface and Ratio controller are not cheap.
    Not sure why they don't just use standard 100/1000Mbit NICs on these wide format MFDs .
    • bellsysoffice
      I just need to find those parts.
      • Cipher
        • May 2006
        • 1309
        Well these are the part numbers of the two main boards (for a repair swap out).
        I can't help you out on where to buy them though, a Ricoh dealership should be able to order them for you.
        B8565570 PCB:Interface Board (RoHs) <---(MFD card)
        B6975910 Control Board (B697-57)(RoHs) <---(PCI card that slots into the PC)
        • Ricoh-ono
          • 339
          Here are 2 Ricoh Direct offices in Arizona. Not sure which one's closest.
          Tucson Office
          3855 S Evans Blvd.
          Suite 405
          Tucson, AZ 85714
          Ph: 520-573-7758
          Fax: 520-573-7798
          Tempe Office
          1700 West 10th Place
          Tempe, AZ 85281
          Ph: 480-619-4940
          Fax: 480-619-4969
          Do what you can, with what you have, where you are. ~Theodore Roosevelt
          • dominic78
            Re: Ricoh Aficio 240w, I need parts!
            Very old post I know but I just came across one of these cards.
