Ricoh MP 305+
  • thurmmy
    • Aug 2016
    • 102
    Ricoh MP 305+
    I am wondering if anyone else has run into this. My customer has a MP 305+ that jams in fuser on the first copy/print/fax of the day. The rest of the day it is fine. I am perplexed. I increased the ready temps. up by 5, but that doesn't seem to have helped. Any comments?
    • 37556
    Re: Ricoh MP 305+
    Considering that you are in Colorado it could be overnight condensation on the top sheet of paper in the tray.
    • anothertech
      • 1771
      Re: Ricoh MP 305+
      MP 305+ pub 20.pdf
      This looks like it might be the answer.
      • JonManchester
        Technician / Shop Manager
        • Aug 2013
        • 103
        Re: Ricoh MP 305+
        If its jam code 20 it's the fusing exit sensor sticking. Remove sensor and examine the surface that the flag seats on. You will see some residue from the fuser. Always replace the exit sensor when doing bulletin. Take the old sensor apart and the inside of that sensor will have cigarette like tar inside the sensor. The reason it jams once is because of that flag sticking causing paper to crash. Once the flag gets unstuck and warmed up it doesn't happen again until machine is cooled down. I found if you do a call like that without a sensor you can put a drop of fuser oil on a q tip and wipe on flag sensor surface, that will keep flag from sticking till part can be replaced. D205-4408 is flag number.
        Live for something or die for nothing.
