ricoh mp 5002 error "preparing an authentication device. Please wait ."
  • trunghuynh20202020
    Technician_kyo
    • Oct 2021
    • 22
    hi all , the area where i live , a customer has ordered a used ricoh 5002 , the machine has a card reader connection , but has lost the admin password wait ." , I adjusted sp5420 to 1 =off for all sub-items ,sp5401:103 to 0 ,sp5401:162 bit 0 and 7 to 0 , sp 5401:230 bit 0 to 0 ,sp 5401:240 bit 0 and 1 to 0 , but still not working , i don't have admin pass to turn it off , i have cleared all 5801:1 excute , replaced 2 FRAM on BCU but still the same error , can anyone help me with any solution now to turn off me thank you very much
  • GIUBOSS
    • 1435
    Re: ricoh mp 5002 error "preparing an authentication device. Please wait ."
    [ATTACH=CONFIG]53017[/ATTACH]
    Are you a Ricoh technician? Does your customer want the card reader? Resetting 5801-1 does not reset everything at all.
      Technician_kyo
      • Oct 2021
      • 22
      yes i am technician , customer does not use card reader , i have tried everything possible to clear all SP 5801-1 , replace BCU board , but the problem is still not solved ,I'm trying to upload fw , and will report when I'm done with the authentication error when unplugging the card reader, thanks
        • 37489
        But are you a Ricoh trained, certified and authorized technician? If you are why have you not contacted Ricoh Vietnam for assistance?
          Technician_kyo
          • Oct 2021
          • 22
          yes i found the problem may be in sop ssd
