looking at the logging data paper jam counter all jams are pointing towards registration 2. av recently changed the feed station rollers and torque limiter. which stopped causing the paper getting caught behind the tandum tray. i have not seen the machine jam itself but whenever it does its either at registration 1 and 2, mostly at 2. how can fix this problem without having to replace the whole feed station?
ricoh 1060 jams
gary
First, make sure that the registration sensor is completely clean of all paper dust, as well as the relay sensor.
As stated before, check to see if any dv has made it into the gears of the first station.
You'll be spending a lot of time hunting for a reg. cluch as there is no reg. clutch on this machine. A stepper motor drives the reg. section, but there is a black mylar behind the b1 gate that can get worn and cause some jamming problems.
If, after you've cleaned all of the sensors and checked for dv, just do a quick feed station swap and then test, since they are all interchangeable.Bachelor of Science in Information Technology, Comptia A+, Comptia Network+Comment
Nicely said schooltech.
Reg mylars on these are a must for replacing at @1m copies, especially if the customer is using crappy paper. Whip the reg section out of the machine and check them over, you'll probably find they're worn.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Theodore_S
I had the same problem in AF1060....The problem was coused by the dev Unit...I ve changed the xtra kit on the dev unit and the one way gears on the feed unit and the problem was solved!!Comment
