IMC300 shuts down automatic
  • GeorgeBest
    • Jul 2009
    • 516
    Got this weard problem at a customer
    An IMC300 shuts complete off on its self at random times . .?!!
    customer has to set it on to get it worked.
    Never seen this, there's is no timer to shut this machine complete off is there ?
    Also an MPC2504 has the same problem . .
    anyone a clue here?
    thanks in advance
  • Gift
    • Mar 2011
    • 2444
    Re: IMC300 shuts down automatic
    There's indeed a setting for switching off the machine with some sort of schedule week-timer. Not shure if the machine is even able to "learn" the office times like Konica Minolta can do (badly^^).
    • GeorgeBest
      • Jul 2009
      • 516
      But random?
      sometimes it runs for weeks without any problems, and then suddenly it shuts off . . . also the MPC2504 which is standing near the IMC300
      • 8T2
        • Aug 2015
        • 257
        As a South African with our struggling electrical grid I immediately start thinking electricity supply issue if both of them do it. Especially if they seem to do it at the same time. If possible stick a power manager like an inovolt unit on there for a while to monitor the the power. Other than that I have no idea
        Sent from my SM-A305F using Tapatalk
        • Gift
          • Mar 2011
          • 2444
          Originally posted by GeorgeBest
          But random?
          OK random seems odd, same is the fact that it works for weeks sometimes - still it won't hurt to check all power saving related settings - you can try and connect the power of MFP to another room that isn't covered by the same fuse in the breaker box with a cable reel. Usually the customer should experience some trouble with the computers, too if the power isn't stable (unless they use laptops thanks to the batteries).
          • 3ktlc
            • Feb 2018
            • 180
            Definitely check the electrical. Years ago I had a machine that would jam or throw code very randomly. Sometimes it would go 6 weeks with no problems. Other times it would go a couple of days. Always worked while I was there. Finally after a few months, I went there and had the customer hand me a stack of things to be copied. Over a 1,000 pages. Machine ran flawlessly unit I was packing up and it started copying by itself. The machine was the only thing in this room. Electrician traced the outlet and found out it was tied into another room with a pop machine and a fridge. Isolated the outlet and the problems went away.
              • 36835
              Random like possibly a disgruntled employee hitting the power button. Put a security camera where it can monitor the IM C300.
              • GeorgeBest
                • Jul 2009
                • 516
                Powered the machine to another room . . . for the check. (and of course another electricity group)
                • MIKON
                  • Jul 2015
                  • 184
                  Is there a line filter connected . If so possibly line voltage is dropping below threshold set on line filter.
                  • GIUBOSS
                    • 1382
                    For the sake of scruple, check the history of errors sc and in any case do the update of the fw.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3945
                        • 36835
                        The dealership I worked for serviced a couple of national accounts for Ricoh, the customer did not like the local branch and other dealers. When new machines were shipped in, they always included power protection devices.
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3945
                          All these machines had filters; all our installs do.
                          Power filters can only do so much.
                          Even the power monitor we put on the worst offender showed no issues, even when the machine threw several error codes.
                          Admittedly, it was a fairly low end monitor.
                          We ended up losing that customer, and all the machines we pulled and sold as used were completely happy in their new homes.
                            • 36835
                            One th ing I have found that many monitors cannot find and many protection devices cannot block is a bad building.
                              • 36835
                              Ground.
                              I somehow forgot to type ground.
