Cant configure phisical buttons on MP4054
  • menosmola
    • Apr 2014
    • 95
    System settings option button for configure the buttons on the left of the screen (copier, document server, fax printer, scanner) is missing
    Enviado desde mi Redmi Note 8 Pro mediante Tapatalk
  • GIUBOSS
    • 1436
    Re: Cant configure phisical buttons on MP4054
    if I remember correctly you should login first
      • 37503
      Might not be logged in as the correct administrator.
      • menosmola
        • Apr 2014
        • 95
        Thanks, but, no, in admin mode does not appear either
        • giovanio
          • 28
          From the service program check the op panel configuration, it is usually changed between SOP and NOP
          • davel
            • Oct 2011
            • 1105
              • 37503
              But which administrator are you when you login as 'admin' There are 4, 5 if you count supervisor, and someone may have assigned that operation to one of the other 3. The only thing that supervisor can do is change the 4 administrators.
              • Debs1964
                • Oct 2010
                • 1693
                The 04 colour devices did, the 04 b/w still has buttons
                There are 10 types of people in this world, those who understand binary maths and those who don't
                • menosmola
                  • Apr 2014
                  • 95
                  Thank you very much, that was exactly what happened.
                  It has been solved by changing SP5-748-201 (smart operation panel connect setting) from 1 to 0
                  • mrwho
                    Major Asshole!
                    • 4299
                    Thank you for the feedback!
                    Mascan42
                    Ibid
