RICOH MP3555 Toner supply provlem
  • copytrust
    • Feb 2010
    • 118
    I am having a problem with a Ricoh MP3555 a new client call us, the machine doesnt supply toner and its having a toner add indication i can see the machine turns 1 time and then it stops i can hear a noise from the motor, if i turn it with my hand then it starts turning 2-3 times and it stucks again with the noise.
    Since i havent worked with these models any help will be appreciated.
    PS i forgot to mention the client was using compatible toner and i chanced it with the original toner.
  • Drivee
    • Nov 2020
    • 322
    Re: RICOH MP3555 Toner supply provlem
    maybe good toner shake will help..
    • TonerMunkeh
      Professional Moron
      • 3865
      The compatible toner will have taken the pump out I'm afraid.
      Hit it.
      • Drivee
        • Nov 2020
        • 322
        Maybe, it need cleaning. The OEM can make same problem.
        • Gift
          • Mar 2011
          • 2459
          I think there's no pump like in the color models but some sort of "hopper" in the back of the machine with a static pipe and a conveyor screw, perhaps some clogged toner is blocking the drive or the screw/conveyor broke inside that pipe.
          • luca72
            • Oct 2017
            • 1778
            if you give it a help with your hand, and it turns, the motor would seem weak, activate the door actuators, and try sp-5-804-162 (toner bottle motor) and see what happens
            "I'll be back"
