Dealing with custmers unwilling to follow instruction
  • mikadonovan
    • May 2008
    • 2931
    Hi, All. I have an account that runs printed originals from a HP printer, and these pages have a tendency to stick together. Riffling the stack before feeding these stacks works pretty well to alleviate the issues, but no one using this particular machine is willing to do this. I just get constant service calls for a machine malfunction when it is not, and I about ready to quit my job because of it. I run a SMC report (26 pages) printed from the machine for testing, and it works great. How do you guys handle shit situations like this?
    NEVER ASSUME ANYTHING
  • emiliorsg
    • Jul 2018
    • 141
    Re: Dealing with custmers unwilling to follow instruction
    Normally inform the client that he spends a piece of shit paper that just gives him problems . Lately with the prices that paper has, it is more common to find problems like this and very wet paper. I imagine that you have changed the paper feed rollers at some time.
      Unless you're working for yourself, I'd go to my service manager and see how it wants to deal with this.
      If this is your customer, what I would do is put in a fresh ream of paper and prove that there's nothing wrong with the machine. Then I would put in the preprinted originals from the HP printer and prove therein lies the problem.
      The next thing I would do and this is KEY. Tell them that you can't guarantee that this paper is gonna run without issues and they're gonna have to follow directions in order to get the best performance...but that you can't guarantee it will work without jamming.
      The other thing you can do is try different paper. Heavier, lighter...see if anything works better than what they're using. Also make sure that you're using the correct paper settings.
      • emiliorsg
        • Jul 2018
        • 141
        It would also be interesting to know if the HP toner is original because if it is compatible it can cause problems of coming out "softer" and sticking to the sheets.
        • tsbservice
          Field tech
          • 7950
          Indeed some customers don't want to collaborate at all. In this situation I suspect changing paper brand they use in HP with good quality paper will greatly reduce hopefully even stop paper sticking. Then you can demonstrate them cheap paper they use is the reason and tell them where to go next time they call. It's not pleasant but sometimes I like to put f .morons where they belong.
          • tsbservice
            Field tech
            • 7950
            O, I forgot about toner good idea. Compatible has different melting temperature and can be sticky sometimes.
            • rthonpm
              • Aug 2007
              • 2847
              For accounts like that, I'll generally start off easy and put a label on the document feeder with a step to prevent issues.
              I've also had to put labels in paper trays on MFP's where users stack LTR paper on both sides of a DLT sized tray, causing paper jams.
              If the label doesn't work, then I'll try to find a user or two with a functioning brain stem and let them know what to do.
              Step three, let management know and that after the next instance, it will fall under time and materials fees.
              Step four is billing after management doesn't work
              Step five not renewing the account if it becomes more of a hassle than it's worth.
              Sent from my BlackBerry using Tapatalk
                • 37168
                Does the Ricoh(?) that are feeding these HP printouts have print capabilities? If so, it would most likely be less expensive to print directly to the Ricoh. Run the numbers and if I am right, give them to the owner of the business. Most owners do not like paying ant more than they absolutely have to.
                • Zaxxon
                  • 608
                  Would be my first weapon of choice.
                  Please start you post with brand, model, problem.
                  • tsbservice
                    Field tech
                    • 7950
                    This is an ultimate idea! I can't imagine HP better in any way than Ricoh machine same class.
                    • mojorolla
                      The Wolf
                      • 2574
                      Documentation is key. I had a law office, once a week a call put up to remove "sign here" stickers that they refused to remove from the originals. Then I get the classic "my other machine would do it"; fuck you, bullshit.
                      After the third call, sent them a bill for $165. After reviewing the service history with the office manager, we ended up waiving the bill, but we made our point, calls dropped off next to nothing.
                      If they can get away with abusing service, believe me. they will.
                        • 22985
                        Just to break this down a tiny bit further:
                        Is this pre-printed paper just random used paper because they're cheap, or does it have a specific purpose like a preprinted form?
                        If it's just random used paper, there's probably nothing that you can really do. This particular brand of cheapness/stupidity usually leads to broken doors, trays, covers, toner cartridges, etc., which end up in the "billing" category.
                        If it's a pre-printed form, perhaps you have an overlay function available to you, to print the form and the image together in the same process.
                        It's customers like this that are always blaming a machine ... if it's not the Ricoh, it will be a Canon, or Kyocera, or whatever ... and not their own behavior. They'll end up being unhappy with whatever machine or service provided. If you're really lucky, they'll just move on to the next provider and torture somebody else. =^..^=
                          • 37168
                          I had a similar situation with a Martini in the ER at a hospital. IT printed a sheet telling them to remove all labels before scanning. Then they taped that where it covered the length sensor for double letter. Correcting one problem created another, just like governments.
                          • sandmanmac
                            • 3977
                            Long story short, Mika.
                            I had a similar situation where the MP C3003 would take several of their pre-printed sheets at a time from the paper tray -despite brand new rollers, and they about drove me crazy being unwilling to adapt.
                            It's a very small office and all of them are a few sandwiches short of a picnic (if you know what I mean)
                            I finally convinced them and demonstrated how to use the bypass tray, and while it doesn't have the capacity that they would like, they're ok re-loading it a time or 2 when they want / need to run these particular sheets a couple of times a week, and it has worked flawlessly for several months.
                            Maybe this is an option for your client?
                            Good luck. I feel your pain!
                            • KeviM
                              • Oct 2019
                              • 324
                              You never mentioned what Ricoh model it was and if it was taking in multiple pages at once or unable to feeder pages in?
