notarial deed on A3 Europ size (America 11-3/4 x 16-1/2") booklet printed (magazine)
  • Mark Bbb
    • Jun 2012
    • 1662
    Customer scans it notarial deeds ('booklet' printed) and is now searching for a software that un-booklet those scanned deeds into a file that respects the normal read order, so 1, 2, 3, ...
    Do you know of the existence of such software?
    Thanks in advance
  • davel
    • Oct 2011
    • 1107
    Re: notarial deed on A3 Europ size (America 11-3/4 x 16-1/2&quot booklet printed (magazi
    By hand on the glass, page by page. They should have kept the original file that they printed into magazine format. Good luck.
      • 23009
      I'd imagine that you could use a paper cutter and cut down the binding. Once the pages are arranged correctly, you've got A4 duplex originals, which can be duplex scanned either LEF or SEF to create a standard PDF page arrangement. If there is any sort of adhesive on the binding, I'd imagine that SEF would probably scan more reliably than LEF. =^..^=
      • Mark Bbb
        • Jun 2012
        • 1662
        How is 'booklet printing' called in america? In Dutch it is called 'boekje' of 'tijdschriftfunctie', translated it would be 'little book or magazine function'
        Are these terms correct?
          • 23009
          "Booklet" is the correct term for copier functions, yes. Or "two-up" if you're referring to image layout. =^..^=
          • Mark Bbb
            • Jun 2012
            • 1662
            Notarial deeds cutting in pieces? Hmm, i don't think that is a good idea...
            • Mark Bbb
              • Jun 2012
              • 1662
              page 2-up booklet. Software - Album on Imgur
