SR-4150 Finisher, Paper Handling unit, broken part. Is iit the same as the 4140?
  • owelesstax
    • May 2020
    • 16
    On the upper paper handler section of my SR-4150 (booklet Finisher) a part broke. Black plastic, kind of a flapper, the last position before the paper path goes to the staple unit. I doubt I can buy that plastic piece.
    Looking for a reasonable fix, that would be less than buying a whole finisher new. One option I just thought if a used SR4140 (non-booklet finisher) (probably cheaper) if the Upper Paper transport was the same I could R&R that section.
    Richard
    Thanks for all who have been so helpful over the years.
    • 37488
    Re: SR-4150 Finisher, Paper Handling unit, broken part. Is iit the same as the 4140?
    Most likely yes. As probably will one form an older 1000 sheet finisher. Ricoh hasn't changed much other than electronics and color to match the current model copier on those 1000 sheet finishers.
    • owelesstax
      • May 2020
      • 16
      ... Ricoh hasn't changed much other than electronics and color to match the current model copier on those 1000 sheet finishers.
      You wouldn't happen to have one laying around...?
      Thanks for the info. I didn't think about other generations. With all of your experience, what do you imagine the range of models might be?
        • 37488
        No, I have been retired for 7 years.
        • owelesstax
          • May 2020
          • 16
          I knew it had been a while, I really appreciate your commitment to being a resource here.
          Richard
          • owelesstax
            • May 2020
            • 16
            <br>
            <br>I knew it had been a while, I really appreciate your commitment to being a resource here.<br><br>Richard
