mp 5054 with sc 554_2
  • Hosam2
    • Feb 2019
    • 6
    [Error Code] mp 5054 with sc 554_2
    I have an mp5054 with code sc 554, the firmware version is 1.06, and the sp 5 810 does not appear.in a later firmware version, if it appears.Do you know how to reset the code, I mean how to reset the fuse spike?
    P.D. entering with reset + 806182 + C and with reset 143 + C + C, the SP 5 810 does not appear either.P.D. entering with reset + 806182 + C and with reset 143 + C + C, the SP 5 810 does not appear either.
  • 8T2
    • Aug 2015
    • 257
    Re: mp 5054 with sc 554_2
    Please edit post and remove confidential codes?
    If there is nothing wrong with fuser you can reset with a fuse or try the switch trick (never managed to do the switch trick successfully myself though)
    Sent from my SM-A305F using Tapatalk
    • Hosam2
      • Feb 2019
      • 6
      what is switch trick
      • mikadonovan
        • May 2008
        • 2931
        This.
        NEVER ASSUME ANYTHING
        • Hosam2
          • Feb 2019
          • 6
          i do it put my problem it is 5810_2 not exist
            • 37628
            Then you have a bigger problem than just the fusing unit. You may have loaded a corrupt firmware file or loaded firmware for the wrong type of operation panel. Or both.
            • copier tech
              • 8220
              Are you sure its not there? Do you have SP 5810-01 ?
              System/Copy 1.06 is very old try updating to the latest.
              • Hosam2
                • Feb 2019
                • 6
                And teh machine is the MP C5504 not MP 5504.
                i am sure its not there
                and it is mp 5054
                • copier tech
                  • 8220
                  and it is mp 5054
                  Sorry I didn't have my glasses on!
                  The service manual does state it should be there.
                  I would try updating the firmware.
                  SC554 Error Reset.pdf
                  • tsbservice
                    Field tech
                    • 8064
                    Really Ricoh...I have had a great confidence in Ricoh based on what I've read but those bulletins Mika and CT posted are quite disturbing. May be a bad model though.
                    • sandmanmac
                      • 3990
                      Don't panic about Mika's post.
                      That's a just a workaround that some savvy techs have developed in order to NOT have to spend $20 or so on the PICO fuse (which is typically required) in order to reset the code when one is not replacing the entire heating element. I've made one, and use it regularly.
                      ......and they're a great model.
                      As for the poster stating that SP5810 doesn't exist? He won't resolve his SC code issue until he resolves that one. It's absolutely necessary
                      • Hosam2
                        • Feb 2019
                        • 6
                        my problem with sp 5810 how i can resolved
                          • 37628
                          With one exception, every fusing sleeve I have ever replaced was done when the PM count was exceeded. That meant that I did not need the fuse that came in the box with the sleeve. As a result I got to where I carried at least 2 in my parts bag for when I had a thermostat or thermistor go south. Are people throwing them away with the packing when they do a PM replacement?
                            • 37628
                            Make sure that ALL firmware is up to date. Make sure it is the correct firmware for the type on operation panel. After that your problem could be a bad NVram, It could be a bad Controller board or a bad BCU board.
                            • sandmanmac
                              • 3990
                              Well respectfully Tim, I guess you were very lucky, but we all are in very different situations, including (possibly) access to genuine parts in some cases. (My case)
                              My most recent example would be 2 x Cxx02 fuser sleeve failures last week alone, that failed more due to time, and toner build up on the entrance guides, than usage.
                              Therfore, I'm only replacing the sleeve (generic) as a cost saving measure, and not the entire heating element.
                              The are 2 recent examples of the convenience of the reset jig
