Ricoh Feature???
  • emujo2
    • Mar 2017
    • 1579
    [Misc] Ricoh Feature???
    Over in the KM forum, there is a poster saying that his old Ricohs would reprint any job that may have been stopped due to a power outage.." job is sent, for some reason the power must be cycled, at reboot any jobs that had spooled to the device reprint". This is in a Citrix environment so making changes to the driver (not using a Windows driver) does not seem to be an option..My real question is..Do Ricohs save print data in RAM that can be reprinted after a power cycle?..TIA E
    • 23010
    Re: Ricoh Feature???
    AFAIK, no MFP saves print data after power off, especially pass-through print data. The ONLY time print data tries again is if the error or power-off occurred BEFORE the print job is sent through a print driver. The print queue will continue to attempt to resend until the MFP connects again and accepts the data.
    I expect that you were thinking the same thing. I was thinking it too. =^..^=
    • emujo2
      • Mar 2017
      • 1579
      Yeah..I'm calling BS on that post..I think there's more to it then he's saying..Maybe he doesn't know..E
        • 37556
        That is only true if the job has not finished spooling. It can also happen when a door is opened while a job is still spooling or a flaky door switch makes the machine think that a door was opened.
        • rthonpm
          • Aug 2007
          • 2859
          The only way it could happen that it would continue to print after recovery from a power failure would be if the job never left the client workstation or the print server. It's no different than when a machine is powered off for service and then once it's powered back on all of the jobs sitting in the queue start spitting out.
          Sent from my BlackBerry using Tapatalk
          • satins
            • Feb 2021
            • 89
            This is interesting as I am not that aware of the CITRIX environment but had few clients using it.
            The window print command ideally works and tries to print to the X device but after trying for x period it sends into error and the spooled data is discarded.The only way I see it happening in CITRIX environment could be that the Spooler ( print command) is not programmed to discard it when the device goes in to error and queues the job again when the device is powered up after X time.I have seen it happening in customized batch file printing.
            I am not sure about it but this could happen for sure as the device's process is overruled by the print command.
