Anyone know if the Fusor's Nip Pad has a part reference?
  • UNICORNico
    • May 2018
    • 308
    I have a doubt, about a specific part of the Fusion System of the series 03 and 04 (and in general of all those who carry the fusing sleeve).
    I remember reading, that the "Nip Pad" received a modification and that the nylon fabric had been changed (the interlaced) and I am curious if anyone knows if there is reference to that part.
    Does anyone sound like you saw it in a newsletter? I know I didn't imagine it, but now I can't find that newsletter and I think that if a piece code came.
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
  • mikadonovan
    • May 2008
    • 2931
    Re: Anyone know if the Fusor's Nip Pad has a part reference?
    There was a bulletin for the '02 series where the pad design was changed to increase the longevity of the sleeve.
    Sleeve part number for C4502/C5502 went from D1444045 to D1444032.
    NEVER ASSUME ANYTHING
      • 37327
      To my knowledge Ricoh does not make internal parts of the fusing sleeve available. If you have ever had a junior tech who doesn't know what the country codes in the PC are for and orders the wrong voltage sleeve you might understand why. Three days waiting for the sleeve, over an hour drive to the customer. Since it is in the afternoon when the part arrives at the office I get sent out to replace the sleeve. After replacement get a warm up error. Found out that it was a sleeve for 220V and I was on a 110V system. Had to swap the lamps to get it operational. Got home after 7 PM that night.
      • Codex
        • May 2008
        • 694
        for me it was the same last year, my boss ordered a 110 sleeve, and we have 220v here, swap the lamps is not easy.
        Memento Audere Semper
        • UNICORNico
          • May 2018
          • 308
          Maybe it was that newsletter that I saw back in the day... Although I do not know why, he remembered that the reference, made mention of the Nip Pad, not to the whole of the Fusion Sleeve.
          I know what you're talking about. Those silly confusions that make you lose a whole day of work, and pray to the RICOH Engineer in Japan, so that the client does not get bad with you, because you have to come back another day, to finish the repair. xD lol
          • Gift
            • Mar 2011
            • 2458
            I do also recall that modification/improvement they made for the MPCxx02 era.
            There are no official spare parts available for the sleeve unit. Some time ago someone gave me a 3rd party sample fuser sleeve with some silicone oil for refurbishing a xxx3 unit. Even at this point I thought it's pointless because the NIP pad surface looks pretty wasted after >200k prints, causing too much friction (oil is just a temporaary fix then) but I gave it a shot "just for fun".
            Unfortunately there was no fun involved AT ALL because the MPC3003 fuser sleeve is built more complex with more (internal) parts compared to older sleeve units I disassembled/reassembled for lubrication (like MPC2051). After an hour of fiddling aroung that 3D puzzle I became angry and held the thing too tight in my hand and wrinkeled the sleeve so I dunked it in the trash
            • Hrca
              • Jan 2022
              • 9
              Hello folks!
              As youre talking about MPC3003 fuser, recently I've changed two of the sleeves with third party sleeve and everything works fine, it takes me about 45 mins for the pita job, but I haven't had problems with it, everything just works. Ofcourse it wont probably last as long as the original, but for that price it's worth a try.
              Offtopic aside, on one unit I've had strange problem with it, but I doubt its the sleeves fault. So I install the fuser into the machine, turn it on and let it boot up, no errors follow. Then, I go to print the counter, press the button and then the machine just takes about 15-20 seconds to even start to print. I assume it takes long to get hot (?), what happens next is that paper gets jammed just before the fuser, like it starts to get pulled inside and then it stops. I've checked for tension and continuity of the lamps, it measures fine, everything else is fine all of the parts look fine and everything fits together. My only doubt are the thermistors, they seem fine and kinda new even, theres no black crud on them, but when I've had blown thermistors an error pops up. So you get why I'm confused.
              Maybe I'm too much into that problems so I need fresh pair of eyes I guess, help!
              • Gift
                • Mar 2011
                • 2458
                Originally posted by Hrca
                Hello folks!
                Perhaps the internal heat shutters or it's mechanisms aren't properly in place? I remember these parts were hard to handle with just two hands and some bystanders joking about me^^
                • luca72
                  • Oct 2017
                  • 1740
                  Hello folks!
                  maybe you have put too silicone oil, or maybe you haven't waited long enough for it to absorb, then it must have come out slightly from the sides of the sleeve, dirtying the two orange rubber pads on the sides of the presser, which make the traction
                  "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
                  • luca72
                    • Oct 2017
                    • 1740
                    [ATTACH=CONFIG]53235[/ATTACH]
                    to me they always look the same, however the loose parts can be found on alibaba or aliexpress if you want
                    • Hrca
                      • Jan 2022
                      • 9
                      Yeah, I agree they're hard to handle, but they were fitted nicely, tried checking it three times...
                      Interesting take, I doubt there was too much oil but I will check it out and try, thanks!
                      • UNICORNico
                        • May 2018
                        • 308
                        I didn't know there were "compatibles" such pieces. Even so, I prefer not to risk it, enough seems to me with some drums, cleaning blades, for some emergencies.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Don't use compatible parts they rubbish and don't work waste of time and money just buy original sleeve assy
                          Regards Mark
