Admin Password Reset Process in Factory SP Mode
  • craigp
    • Jan 2018
    • 34
    Hey guys,
    I was able to get to the "Factory Service Mode" but when I get in it only takes me to the following screen:
    Is there supposed to be some place where I can go to reset the admin password?
  • GIUBOSS
    • 1385
    Re: Admin Password Reset Process in Factory SP Mode
    Originally posted by craigp
    Hey guys,
    [ATTACH=CONFIG]53372[/ATTACH]
    I do not think you have entered the sp mode, rather in the administrator menu ...
    • GIUBOSS
      • 1385
      You can also do it from WIM by entering the IP of the machine
      • sandmanmac
        • 3979
        Hey guys,
        That is NOT factory SP Mode.
        The is the SOP SP mode
        • craigp
          • Jan 2018
          • 34
          Got it. I've been trying to remove password for admin/supervisor for a while now. Do you happen to know how to get into the Factory SP Mode so I can remove the admin password? If you can please PM so I can do this
          • sandmanmac
            • 3979
            Yes I do, but it was already very specifically provided to you in your OTHER thread about this same issue (although a procedure like that has no business being POSTED IN A PUBLIC FORUM)
            Why have you begun an entirely new one for the same issue?
            • sandmanmac
              • 3979
              Actually.....I just re-read the post with the instructions for Factory SP Mode and was pleased to see there is an error in the instructions
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                You have to do on machine it's easy if you are a credited ricoh engineer
                Regards Mark
                  • 37357
                  And it is easiest using the Classic Copy function screen where you will have all the touch screen buttons needed.
                  • RMC8112
                    • Nov 2019
                    • 38
                    There are two ways.
                    1. Logon to the WIM as Supervisor.
                    2. Enter Factory Mode
                    Reset->143->Clear ->Clear Hold on second Clear
                    The screen will change to SP screen.
                    Click System and goto SP5846-046 Then execute
                    Reboot.
                    Now the only thing with doing this is that the address book will be gone and all the scan settings will be reset.
